DiskDoctr's avatar
DiskDoctr
120v only lights in slide- convert to 12v?
Our 2005 Cougar 304BHS living room/dining slide ONLY has 120v lighting, one over the table and one over the couch. Boondock = no lights (!)
I have a few questions about "fixing" it.
1. 120v only works when the slide is out all the way. Is there a switch someone knows of (where?) with a relay or whatever to control that?
2. Anyone know where/how the wiring is routed through the slide to the main cabin?
3. Opinions on simply converting the 120V lights to 12v LED? They have standard incandescent twist in (house) light bulbs in there now.
4. I saw someone used LED puck lights, but they were $25/ea.
5. Dimmable? How many? Ideas?
I'm thinking about adding a 12v REGULATED circuit if I run new wires for new light, giving the ability to use standard "under cabinet" LEDs, which seem readily available, with dimmers. It would be a separate fused circuit and regulator in the convertor housing area, for lights only.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,320 PostsLatest Activity: Sep 20, 2025
