wa8yxm
Aug 06, 2019Explorer III
RICH807 wrote:
Question: Can using a 12/24v solar controller lashed up to a solar panel send too much voltage to 6v batteries effectively killing them prematurely?
First Though I now when you take 'em out and put 'em on the bench or in the back of the truck to haul to the battery store they are 6 Volt Golf Car batteries.. WHEN they are properly installed (See below) in the RV they are two halves of a single 12 volt battery.. Think of them that way and many questions self ansere
Proper (wires are represented by the equals sign)
Frame ====-(6v)+===-(6v)+==== 12 volt to RV
Second to answer the question quoted. ANY Charge controller or system has failure modes
One mode is : It does not do anything
One mode It never goes into "Bulk" or fast mode
One mode It never comes out of fast charge
one mode. it never switches to FLOAT
And that is ONE possible problem you have (The last fail mode not going to float)
IT is also possible the battery (one of the halves) has a shorted cell,
