Sam_Spade
Mar 01, 2017Explorer
CheeseEater88 wrote:
Would it be easy to convert the system to 24v or 48v DC for the battery side of things?
NO, absolutely not.
Not easy, not cheap and NOT necessary.
You would be better off spending your time and money:
Increasing the 12 V battery capacity
Making sure that you have a good 3 stage converter/charger.
And maybe adding some solar, depending on your usage patterns.
This assumes that there is a generator available to create AC when you need to run things like the A/C, microwave and often the TV.
By getting a 12 V TV, I found that I cut my generator time WAY down.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
