Sam_Spade
Mar 01, 2017Explorer
CheeseEater88 wrote:
I am at this point tempted to leave the existing 12v setup alone for simplicity,
and doing an invert/charger 48v to power some of the 110v outlets.
And then simplicity went right OUT the window. Really.
What advantage do you think it gives you taking 4 12 Volt batteries and hooking them in series for a 48 V system ?? It really makes more sense using them to increase the capacity at 12 volts. Really.
A generator solves a LOT of problems.
But if you want to try and design a better mousetrap, there are quite a few on here who will help you implement whatever kind of setup you can imagine. That does not mean, however, that it is a good idea.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
