MrWizard
Mar 02, 2017Moderator
At the OP
Have you looked for 24v lithium in the amount of amp hours you want
It has to be built as one pack with cell charge balance management for each cell
You can't just stick two 12v lithium in series like you do with less acid
They don't even work well paralleled
One pack pre built at the volts and amp hours
You seem to have the cash to do what you want, just need to be aware of what is feasible and what is not, you can't expand a lithium bank the way you do less acid
Amp hours voltage charger etc..
All installed as one system
Good luck
Any sla system you put in, will have to be removed and replaced if you go lithium, this includes the charger and battery bank
Good luck
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
