MrWizard
Mar 02, 2017Moderator
new 12v batteries, new location ?
just connect them to existing converter for charging, place inverter as close as possible for the power draw and short wires, remove batteries from tongue
(1) set of batteries for house and inverter
even with our MW we seldom pull over 120amps and only for minutes at a time
no way will you be running the A/C for hours, you probably never see that 200amp load , you will need that generator some times
we use ours almost every day
what you need to redesign and upgrade is the charge wiring between tow vehicle and TT
not re-engineer the house side
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
