Yellerledbetty
May 30, 2021Explorer
Flute Man wrote:
Did you check the 120 V circuit breaker that feeds the converter?
On that connection you previously tightened remove it and clean it up and then reinstall.
You may call me if you wish and I might be able to help you over the phone. I am a retired professional electrical troubleshooter.
Sorry for the delay with this. the '120V circuit breaker that feeds the converter' would be in the electrical panel of my RV,yes?
I will look back at all the connections and ensure clean/secure. i think that I am leaning towards ruling out any issues pertaining to reversed polarity b/c the Mfg. of the converter notes that it is wired to 'accommodate' such errors. As such I think perhaps it is, like you'd noted, a loose/dirty connection or perhaps some worn cables that might have rubbed on the chassis of the trailer (or similar) and is creating a short somewhere. Is there a way to 'test the frame' with a volt meter to see if there's a short resulting due to this? Nobody has received a *zap* because of this. I have checked the fuses in the Truck and they are fine.
TIA!
Bri@n.
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
