Yellerledbetty
May 30, 2021Explorer
cavie wrote:
Have battery load tested. check "reverse Polarity" fuses on converter. Disconnect 12 volt output wires from converter. Test voltage out of converter. Look for resetable 12 volt fuse under toung ofn trailer within 6' of the battery.
Hi there - We've almost lost track of how many times we've replace batteries (just kidding! but it's been 2-3 times over 7-ish years of ownership since new).
Re: "Look for re-settable 12 volt fuse under tongue of trailer within 6' of the battery" should there be a fuse somewhere along the 'load' wire running off the converter --> battery? I will have a look.
Thanks!
Bri@n
Having RV issues? Connect with others who have been in your shoes.24,400 PostsLatest Activity: Aug 08, 2019
