time2roll
Jun 19, 2013Nomad
Most MPPT that charge different battery voltages will auto detect the correct voltage. But you need to connect in the correct sequence as described in the manual. Otherwise if it is in the description it will work fine.
May as well post the full controller make and model number.
You cannot charge 12v and 24v battery at the same time. One or the other.
