Old___Slow
Jun 20, 2013Explorer
HiTech Jim,
I'm finding out why in school and upwards, classmates gave you the handle, Mr. Hi-Tech.
I pulled the battery out of the e/scooter. Here is what I found. RU (the R being backwards) CE MH 26669 SUNNYWAY SW 12120 (12v12Ah) Rechargeable Sealed Lead-Acid Battery~SUNNYWAY BATTERY TECH CO.LTD. Made in China charging Instructions at 25c
Standby use 13.50-13.80 Initial current 0.1c Cycle use 14.10~14.40 IC 0.25cmax Production date 2011.4.11 CCA144 My great hope is that I can extend the run time with the 24v/120w Panel. Will it travel all the way to LA, I da' know!?
The papers that came with the scooter stated it had 18Ah batts. Hmm.
The two batts are wired in series.
O&S
Floyd
Side note: The 24v motor and gears name plate is " Warner." Is that not USA?
O&S
Floyd
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
