KJINTF
Jun 22, 2013Explorer
Just a guess it might boil down to a design parameter and parts costs
The 30 amp version - Can handle less power so with less of a internal heat issue they might have choosen different parts for the input stage which resulted in a higher max input voltage. Either way a 100 Volt max input limit should be enough for either system using a series parallel array connection.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
