Resoman's avatar
Resoman
12V battery issues
I bought a new battery for my 2013 Forest River PUP last fall and stored it in the garage, giving it a full charge every month and disconnecting the charger (NOCO G1100) between charge cycles.
When I went to use the trailer this spring, I found that the A/C unit and the lift mechanism had died over the winter, had them both replaced, to the tune of $2K.
I got the rig home from the shop this week, took the battery into the garage and hooked up the charger. I was surprised to see the charger initially indicate only a 25% charge, and left it connected overnight.
Today, it's still showing only 25% charge, and I'm concerned that I've had another battery die on me. Water levels look fine.
I assumed that the one hour drive home from the repair shop would top off the battery charge, is that reasonable? It sat at the repair shop for two months.
Tomorrow, I'm leaving town for a couple of weeks, but will leave the charger connected for another 24 hours and see if things improve.
I'm in sunny Texas, FWIW.
Any thoughts from battery experts will be appreciated!
Having RV issues? Connect with others who have been in your shoes.24,368 PostsLatest Activity: Mar 11, 2026
