Bill_Diana's avatar
Bill_Diana
12v Converter Replacement Advice
Back in September while camping I happen to notice the lights on the refrigerator flickered. Then everything seemed normal again. I did some research and think that the flicker may have been caused by AC ripple from the 12v converter which is about 18 years old.
Now we are on another 6 week trip and last night while doing dishes my wife commented that the 12v light above the sink seemed unusually bright. I told her that I noticed all the lights in the motorhome were appearing brighter than usual.
This morning I got out the voltmeter and measured the voltage at the coach batteries and was not surprised to get a high reading of 15.4 volts.
The present 12v converter is rated at 50 amps. I'm thinking about purchasing a 9200 Series Progressive Dynamics converter. One unit is rated at 45 amps and another at 60 amps. Which would you suggest I buy?
Also, if I buy the Progressive Dynamic converter here while in Myrtle Beach the unit will cost $322. If I buy the unit online from PPL Motorhomes I can get the same identical unit for $175. It will take one week before I can get the unit by ordering online. So, the question is....would it be safe to wait to replace the unit and continue to use this old converter even though it is putting out 15.4 volts?
Thanks in advance for your comments & suggestions.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
