Sam_Spade
Sep 18, 2017Explorer
What you NEED IS......
A multimeter so you can test the voltage at various points to narrow down the problem.
Guessing and throwing parts at a problem like this often turns out BAD....meaning time consuming and expensive.
Most likely causes:
Loose or corroded main battery cable connection.....including the main battery disconnect switch/solenoid.
Intermittent open connection INSIDE one of the "newish" batteries.
Most likely causes:
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
