fandango49's avatar
fandango49
12V house battery issue
Need help with a 12V issue.
Travel trailer's 12V battery is fully charged, electric jack works. No lights or 12v accessories inside unit work on 12V. When the cord is plugged into tow vehicle everything works and works when plugged into shore power only.
Found a junction were 12V from battery enters and joins up with the 12V
from tow vehicle, was a plastic connector that had broke in half that has terminals to connect the wires.
My question is this some type of diode or something? Is it OK if house battery, tow vehicle battery and on board converter are all tied
together with just a single connector?
  • FWIW, most electric jacks are connected directly to the battery with it's own fuse.
    I always thought that the breaker others are talking about was a large fuse.
    Ron
  • That "junction/connector" may be what's left of an inline circuit breaker. Nearly all RV's have a circuit breaker close to the battery. This is to protect the battery cable and connected circuits from drawing full battery power in case of a short.
  • Your battery path to the fuse panel is open. Yes the various sources of 12v can use the same path. Here is a Komfort 5er's for example.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
