I have an issue where when I am not hooked up to shore power or have the generator running, I can't turn on many 12v accessories. I'm talking even too many lights without the lights dimming and then m...
Just because the battery shows good on the DVM doesn't mean it's a good battery. A battery can go "high impedance" where it will show just fine on a meter (because the meter impedance is several million ohms and presents no "load" whatsoever), whereas drawing any kind of current, even from some of the brighter LED's, it simply cannot do.
That's why the standard battery test is called a "load test", where you put 50-100A on a battery and see how it holds up. Yours would certinaly fail
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
