I have an issue where when I am not hooked up to shore power or have the generator running, I can't turn on many 12v accessories. I'm talking even too many lights without the lights dimming and then m...
12.3 on the battery should start the generator. Dropping to 9 volts while trying to start the generator is not normal and indicates the battery is shot. The long shot would be a shorted starter motor on the generator.
LED usually has a voltage regulator so they do not dim the same as incandescent. At around 9 volts would be cut-off to just quit.
I never have understood why a generator starts from the house battery instead of the chassis.
Having RV issues? Connect with others who have been in your shoes.24,407 PostsLatest Activity: Aug 16, 2026
