enblethen
Dec 23, 2014Nomad
Put a volt meter on the 120 volt output. It can be plugged into a receptacle.
It could be a failing voltage regulator.
You could do it on a 12 volt DC circuit or at the battery as the converter output would rise and fall as 120 volt AC input changes.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jan 17, 2025
