kaydeejay
Mar 08, 2015Explorer
chrisinkanata wrote:You may have a resettable circuit breaker in the line from your trailer umbilical cord to the battery. Follow the wires through to see if you can find one. It will NOT be part of your power panel.
So we have a new Grand Design trlr. On this trlr, if the battery is at 75% on the panel and I plug it into our truck, the voltage doesn't change. Even after driving all day the voltage will not have changed. Confirmed 12v at the connector on the truck. Every other trlr we've had, when it gets plugged into the truck, the panel indicates 100%. This is a pain because if the battery is low, there may not be enough juice to power the pump for the LevelUp front legs so unless I have my generator with me, I'm stuck.
BTW...disregard the trlr in my sig. Any thoughts?
Chris
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
