TucsonJim
Mar 08, 2015Explorer II
Our Grand Design batteries are charged when we're driving. I know you said you checked the power at the truck, but just in case you want to check it again, here's a diagram for checking it out:
Set your volt meter to DC volts and make sure you're measuring about 13.5VDC between pins 1 & 4 with the truck running. If not, track down the issue with the truck.
If you confirm the 13.5 volts at the truck, check the voltage at the battery on the FW. You'll probably be between 12.0 to 12.6VDC. Then connect the 7-way plug between the truck and the trailer. Start the truck and verify that you now have about 13.5VDC at the battery. If not, the problem likely is in the FW and you need to track it down. It could be something as simple as a blown fuse.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
