RJsfishin
Mar 09, 2015Explorer
Dakota98 wrote:
The monitor panel is useless anyway. If you want to know battery SOC, @ minimum get a voltmeter & install it.
The panel meter IS AN ANALOG VOLT METER. It may not be as accurate as a digital read out, but it works fine for knowing if the charging system is working or not. I have never seen one fail. In your case you can bet the TVs charging system is not making it to the trailers 12 volt distribution center, which should be at the other end of the trailer's 12v connector cord.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
