ru4nd2's avatar
ru4nd2
12v power
I have an 08 Rockwood Ultralite 5er. Model8281ss. When I am hooked up to a vehicle or shore power I am able to have 12v power, but when I am unhooked from either of these I cannot use any of the 12v items (lights, front power jacks, etc.) I took the battery out and had it charged and tested. Everything checked out okay. 12.2volts after a charge. I checked for corrosion on all the wiring to and from the battery, pulled it all apart cleaned it and ohmed out the wiring. Everything looks and tested good. The fuses all checked out okay also. Am I missing something. Why can I still not get 12v power unless I am hooked up?
  • Ditto on what others have said. In addition, your battery doesn't sound healthy. 12.2 volts after a charge of how long? Have you checked the water levels in it recently?
    Consider the following:
  • I'm guessing the converter on my unit is on the bottom side or behind my electrical board and breakers under my fridge?
  • you either have a resetable fuse or a badfuse coming off the battery isolating the batt out of the circuit
  • The battery is not connected to the converter. You either have a disconnect open or perhaps you have connected the battery backwards or shorted the converter and blown the reverse polarity fuses on the converter.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
