CA_Traveler
May 26, 2020Explorer III
Your link sounds like a concern for corrosion which can become a problem. Good maintained grounding would do the job. 10 ga is likely over kill for the running lights ground especially for LED lights.
Are you going to use the TV to charge the trailer battery? Regardless I'd ground the 12V interior system including any incoming AC to the trailer.
Aluminum conductivity would not be a concern for me but long term corrosion can be a issue.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
