SlideInDad
May 26, 2020Explorer
CA Traveler wrote:
Your link sounds like a concern for corrosion which can become a problem. Good maintained grounding would do the job. 10 ga is likely over kill for the running lights ground especially for LED lights.
Are you going to use the TV to charge the trailer battery? Regardless I'd ground the 12V interior system including any incoming AC to the trailer.
Aluminum conductivity would not be a concern for me but long term corrosion can be a issue.
Trailer house batteries will be charged by solar and a IOTA 45 converter when connected to AC via either a generator or when at home. Exactly what do you mean regarding a well maintained grouding? Cleaning were it grounds to the frame from the batteries frequently?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
