Chris_Bryant
May 21, 2015Explorer II
Is it cycling on and off, or just not keeping up? Cycling- make sure the thermostat capillary tube is in the correct position, mechanical thermostat has a bottom temp of ~65-70.
Not keeping up- measure inlet and outlet temps- should be around 17-20 degrees difference. Make sure all of the collars are in place, and air isn't leaking between return and supply air.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
