Vulcan_Rider
May 22, 2015Explorer
DBHMEH wrote:
The primary is the main ducted unit with a wall thermostat and it freezes the entire living area. I would think one 13.5 would freeze a small bedroom, however, nope it does not. the thermostat and controls are integrated in the 13.5.
Alas, I think the "logical" conclusion here turns out to be wrong......partly because of the design of your new unit and having it in a space that probably is MUCH smaller than it was intended for.
If you run the fan continuously the temp might be more stable but the humidity likely would go up so it might not feel that much different.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
