Chris_Bryant
May 22, 2015Explorer II
DBHMEH wrote:
Sorry, not "R" rated, what one wrong letter can do. Simple fix, hence poor design. Took the shroud down inside and noticed Coleman utilizes a flexible shoot or duct to blow the cooled air. If the "boot is not absolutely sealed to the plastic air channel, it will leak/blow the cooled air on the thermostat tube and give the unit a false temp. Again, cheap design. No RV repair is going to take the time to fix/sea; this adequately. Also, no I dont always run it. Just a boost during the hot hot days and while we park and run the gen. Thanks guys, should have taken pictures. David
Glad you found the problem. That design is somewhat problematic, but better than the Carrier was, and it just takes a small bit of care when installing to make it right- it should *never* have been released leaking like that.
Not sure how portables wormed in to this thread though....
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
