TexasRedNeck's avatar
TexasRedNeck
13,500 BTU vs 15,000 BTU second AC
Long story short, I bought a new 5th wheel and paid to have a second AC installed. The ducts run from the bunk house to the front bedroom and I specified a 15,000 BTU connected to the existing duct work so that the increased capacity would be available to all parts of the trailer and not just the bedroom.
The dealer made a mistake and installed a 13,500 BTU and not the 15,000. So far they appear to be willing to help resolve the issue since I discovered it after some minor wiring glitches had to be tracked down. The selling dealer is not local nor convenient.
They are saying the Dometic rep is telling them that they don't recommend ducting a second 15000BTU AC as it will cause the evaporator to ice up. They are also saying that ducting a 13,500 "makes it 15,000" BTU.
Now, I'm no expert here. The rating of BTU is the capacity for heat transfer which I see as a function of the compressor and evaporator sizing and not affected by ducting or not ducting.
I'm trying to be a reasonable consumer and work with these folks and would like your expert opinion on the use of 2 15K units versus 1 15K and 1 13.5K. Remember this is deep South Texas where summer camping means high humidity and nearly 100 degree heat with regularity from June through September.
Thanks in advance for your advice.
Having RV issues? Connect with others who have been in your shoes.24,327 PostsLatest Activity: Oct 26, 2025
