pianotuna's avatar
pianotuna
Nomad III
Nov 20, 2016
15 amp fuse replace with a breaker
Hi,
I'm wondering if any company makes a 15 amp breaker to replace a 12 volt blade fuse? Of course it would not be cheap as it would have to be arc fault protected.
  • ScottG wrote:
    Yes, you can go to someplace like Orielly's and they have a full selection of blade type breakers that will plug in place of fuses!
    Not sure what you mean about the arc fault part though. I dont know any 12V breakers that do that and with the pain they cause in 120VAC systems, I wouldn't want one - but thats just me.
    All breakers have a so called arc fault. It's the ability to suppress the arc when the breaker opens under load. DC breakers typically have a higher value then AC breakers.
  • Yes, you can go to someplace like Orielly's and they have a full selection of blade type breakers that will plug in place of fuses!
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
