Fishinghat
Jul 31, 2014Explorer II
The GFI (ground fault interrupter) outlet in your RV is not dependent on the 120 volt power plug adapter's, unless you have disconnected the ground or crossed the wires somehow.
The adapter should allow 1/2 of your RV to be powered by the 15 amp source and the other half by the 30 amp source. Fifty amp power means the RV has two circuits that can draw 50 amps each, but they are not "combined" since that would give you 240 volts, and that would destroy your RV's electrical system. (That is, unless you have a VERY high end coach with a 240 volt system.)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
