Bill_Satellite
Aug 01, 2014Explorer II
ecguyer wrote:
so then the y Adapter is no good because all of the parks have a GFCI on the 20 amp side. is their no way around this?
Current electrical code requires the GFCI in the circuit even if you don't see it in the box. If the campground has old wiring and does not update any part of it I believe they don't have to come up to code until they do.
If there is a GFCI anywhere in any circuit used the Y connectors will trip it immediately and there is no way around that. The last time I was able to use mine was when we were in a park where the 50 was not working properly and I used the 30 amp in my box and ran an extension from the 30 amp in the site next door. I still didn't have 50 amp service but as long as I limited each leg to 20-25 amps I was OK.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
