TomG2 wrote:
As always, there are other options. One does not have to raise the bridge if they can lower the river instead. Depending on where and how the OP uses his rig, perhaps a 11k unit might suffice? Mine ran off a 2000 watt generator just fine.
In principle, I agree with your suggestion. However, it's possible the OP could inadvertently purchase a very inefficient 11k BTU RV a/c unit with an extremely high LRA, have less cooling, and still have problems starting it with a 2k inverter generator. Granted, unlikely, but possible.
As I stated earlier, an RV a/c unit's BTU rating is
not an
accurate indicator of how much power/current it needs to start/run properly.
The manufacturer's LRA and continuous current ratings provide a much more accurate picture of the power/current necessary to start and run a given RV a/c unit. IMO, not a good idea to make important power decisions based on the BTU rating.
