2oldman wrote:
2 of the 2200's would easily do the job.
TomG2 wrote:
Two 2000's would easily do the job also.
Not sure what job you're referring to. But, for anyone considering the purchase of a 2nd EU2x00i (to parallel with another EU2x00i) it's important to keep in mind what you are getting and what you're not getting. Paralleling two Honda EU2x00i's will double the continuous current output, but it will
not double the inrush current output. When two EU2x00i's are paralleled the inrush current only increases 10-15% (vs. one EU2xxxi). What this means, if you're powering non-inductive loads (heater, lights, etc.), then yes you're going to get twice the performance with two EU2xxxi's. However, if you're powering inductive loads (i.e., an a/c compressor, electric motor, etc.) with significant inrush requirements, you'll only get 10-15% improvement in "start" (inrush current) performance--which is not a lot.
In testing I've found two EU2000i's begin to have difficulty starting an RV a/c unit with the Eco mode
on when the LRA gets much higher than 60 amps or so. With the Eco mode turned
off, it does well starting a/c units with an LRA up to approx. 65 amps. Above that, it's hit or miss. One EU2000i, with the Eco mode on, can start an a/c with an LRA up to approx. 50 amps. With the Eco mode off, slightly better at 53-55 amps.
Disclaimer (to keep the generator police at bay--lol!): You may or may not find these results applicable to your specific application. Operating conditions can change these results dramatically (temperature, humidity, altitude, generator condition, a/c condition, etc.).
