nvreloader's avatar
nvreloader
16" -5 hole rims?
I had an OLD 1970's era, 20' Terry Brand RV, it went to the dump and the sawzall came out.
A short time later, I had a 8'x 20" empty dual axle w/electric brakes bare frame sitting there.
This frame has 5 hole/15" tires/rims/axles.
Being that I have numerous 16", 10 ply lightly used LT tires, that I want to use on this frame, to give a tougher tire option.
BUT, I cannot find ANY 16"-5 hole rims any where.
It appears that I will have to change the 15" -5 hole axles/rims/wheels to 16"-6 hole wheels/rims, unless I find a solution?
ANY ideas/suggestions on how to convert to the 16" tires I want to use???????
Tia,
Don
  • Horizon170 wrote:
    Some of the older Ford pickups had 5 lug 16" wheels, I know that my '48 Ford coupe did also. Depends on distance between lugs. Try Dodge and GM also.
    Make a template and visit your local junk yard.
    X2^^^^^
    I did that with my old TT. Had a friend who is a Ford hoarder. Needed a spare tire and rim, and the Ford rim fit like a glove. Then traded him my four 15" rims for four 5 bolt 16" Ford rims and bought new LT tires for them. Was a perfect fit.
    Tia,
    Don
    That TT should have 3500# axles. The 5 lug and 6 lug drums are interchangeable and pretty cheap.
    They even came with new bearings, seal and lug nuts when I did it.
  • Landrover rims are all 5 bolt on 6.5 pcd, most were 16 inch and quite narrow, so might work for you. Sorry just noticed you measured the PCD and it was 4.5.
  • Can't you replace everything from the spindles out? You should be able to find new hubs that would fit the spindles, maybe with disc brakes.
  • mrekim wrote:
    If you can get some info on the axles, you may be able to get new brake drums with a bolt pattern that will work.
    This is how I would try to remedy the situation. Etrailer.com is a good source for what you need.
  • If you can get some info on the axles, you may be able to get new brake drums with a bolt pattern that will work.
  • Some of the older Ford pickups had 5 lug 16" wheels, I know that my '48 Ford coupe did also. Depends on distance between lugs. Try Dodge and GM also.
  • Smkettner,
    Thanks for the info.
    Just measured the axle,bolt pattern is 5 on 4.5".
    Those 16" rims are just 1" TOO big, at 5 on 5.5".
    I may have to change the spindle/drum to the larger size of 6 on 5.5", which means I'll have to change out the electric brakes etc.
    Tia,
    Don
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
