eHoefler
Oct 06, 2016Explorer II
Expand you search to include Ford wheels for the same years, they used the same wheels. DO NOT remove the location pin if you continue to use the OE wheels for the that year. The pin forces you to align the wheels correctly. They have every other hole raised and recessed, they have to line up to stay tight when dualled, they also are hub piloted and use acorn nuts. You can go to the newer flat wheels, you will have to remove the relocation pin and go to flange nuts. You can not mix them, it is all or nothing.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
