dougrainer
Jun 13, 2014Nomad
unbob wrote:dougrainer wrote:Mine is removable. Or can easily be cut off with scissors or knife.
The gaskets are molded to the door frame and not removable.
They are removable by cutting them. That does NOT mean that there is a replacement gasket. You buy the WHOLE door as I stated. I just talked to Dometic. Dometic only supplies the gaskets for the RM 1350 model refer as this is the only model with factory replacement gasket. There is a aftermarket company that makes and sells the replacement door gaskets for the various models thru Dometic. You MUST remove the door and glue and silicone the new gasket for at least 24 hours dry time. Dometic does not set the price of the gasket. The aftermarket company does. That is why I state to just buy the complete door for a few dollars more. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
