Chris_Bryant
Jun 14, 2014Explorer II
unbob wrote:Chris Bryant wrote:Damage to the original door gasket is irrelevant since I'm removing it before installing the rubber bulb seal.
If you managed to damage the original gasket (which is pretty tough material), that bulb seal won't last a month.
I mention damage, because that is the only reason to replace the gasket.
Re the longevity of the bulb seal, I'm assuming you make that statement based on first-hand experience. I've had rubber bulb seal installed on an outside aluminum box on my truck for years and it's held up just fine - and the bulb seal is compressed very much.
You assume correctly
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
