zozomike
Mar 17, 2014Explorer
1983 Fleetwood wilderness
Hello folks, I really hope you can give me some time and good ideas! We are building an off grid all solar homestead in the southern mountains of NM. (OK, just wait for the part that applies here.) We have currently only 2KW of PV, will be adding another 1.5KW in a few weeks. But my way bi-polar son recently lost all other housing options so we picked up a 1987 travel trailer as noted above and he is happy on the land.
What is not OK is that since I trenched and installed an RV hookup (120VAC + water supply and grey water disposal system,- (for blackwater see-http://www.builditsolar.com/Projects/Water/SolarLoo/SolarLoo.htm)
I find that the trailer is pulling over 5 KW in a 24 hour period even if he turns nothing on,(Killawatt measured with everything, even the Norcold turned off.)
So it seems obvious that the antique 40 watt converter is the power hog. It is drawing 220 watts 24/7= over 5 KW in 24 hours
Now I'm pretty inverter/battery/PV/wire friendly as I have built our power system from the ground up (with many embarassing missteps.) But I have not dealt with RV converters. I don't want to trash the noisy thing as 12VDC is needed for the lights and pump and Ref ( can't get the propane option to work yet but the electric freezes too much) And I never know if he will get cool , get a pickup and join you on the road.........
I'm not sure if I should pull the converter plug and add a 12vdc wall wart for the lights( change to led as we use?) /pump/ref or replace the antique converter with something which has low standby use. Any ideas?
