- Sam_WhiskeyExplorerI forgot..tow vehicle will be a 2001 Ford F250 Super Duty 5.4 v8
- Sam_WhiskeyExplorerGreat responses! I thank you all! I ask about the WDH (we have one) because the original owner of the 93 coachman (about 20 ft) we currently have told us the dealer advised them not to use a WDH with that trailer...couldn't handle it..but she didn't remember the details. I may have to move the propane tanks around on the Wilderness to install a WDH...sigh.
Will check the cabinets and try the digital photo method for weight.
THANKS AGAIN! - Doug33Explorerwhat will you be towing with?
- OaklevelExplorerI would highly recommend using a WDH !! We used d one on our 1988 and 1973 Fleetwood Terrys.
The stickers fading out is a common problem with 99.99% of trailer stored outside, I have same issue on a 1994 cargo trailer, and a flat 2003 car trailer.... I know of no way to make them readable. I would search the internet for the info like GVW etc. Weight would best best to take it to the scales. Sam_Whiskey wrote:
About to purchase this but label with model, weight, etc is unreadable. Is there a trick to bring out the info on the tag (some chemical, etc)? Also, is it safe to use a WDH on this model? Thanks for your time!
You might be able to take digital picture and then play with on the computer, adjusting contrast, brightness, etc.. maybe even black and white..- old_guyExplorera TT that big I wouldn't tow across the street with out a WDH.
- azrvingExplorerSome models may have the load info inside one of the kitchen cabinets. I dont know if they did it back then.
