oldtrojan66
Dec 25, 2015Explorer
Well, at the risk of stepping on someone's advice toes, I would suggest a different first step. The thermocouple is the little thing the flame goes around when it turns up a little. The oil in the bellows (the little tip inside the flame) expands and opens the safety valve. If the flame rises but does not open the safety valve (flame from main burner), the thermocouple is likely the faulty (and less expensive) part. The thermostat's job is to raise the flame size and sense the oven temp and shut off gas when temp is reached. Just my $.02 from 35 years on appliances. Hth
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
