jonfrontexas's avatar
jonfrontexas
1992 pace arrow headlight issues
Hi all. I am looking for help on my headlights. Right now the brights work but the low beams do not. I am thinking that it's a relay but I cannot find the location of the relay. It is not in the relay box up front under the hood. And it is not near the fuse box located inside the cab to the left of the gas pedal. I'm trying to get this darn thing inspected but need the headlights to work in order to get it done. Any help would be greatly appreciated. Thanks.
  • j-d's avatar
    j-d
    Explorer II
    Just gOOgle "1992 ford f53 wiring diagram" and you'll get hundreds of links and images. Somewhere in that, you may find an exact match. I sent you the best I could find in a reasonable amount of my time. Crawl around in all that and you may find exact.
    This is Ford's Truck Body Builder Advisory Service[url=] page. You'll see it only goes back so far. But there's "Contact Us" info that might help.
  • Well it helped me realize that there may be two fuses for my low beams, but it was a 2004 model so the location of the fuses are off. But thank you.
  • j-d's avatar
    j-d
    Explorer II
    Chris Bryant wrote:
    could be a coincidence that both burned out at the same time.
    Happened with a friend's Chevy Trailblazer. She and another friend were tearing the thing to pieces. Both stop light bulbs were burned out.
    OP - take that web address and see if you can back into 1992. Just glancing at the page I sent, 20A fuse (somewhere...) for the high beams.
  • Just for fun, make sure they are not getting power- it could be a coincidence that both burned out at the same time.
  • Hi, thanks so much for your reply. It's a 1992 ford 460 Fleetwood Pace Arrow 30 ft. please let me know if that is enough information for you.
  • j-d's avatar
    j-d
    Explorer II
    What is the Make Model and Year of the Chassis this Pace Arrow sits on?
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
