enblethen
Jul 20, 2018Nomad
There should be a fuel pump relay mounted to the right side of the engine on a reinforcing strut. This supplies power to the fuel pump for a few seconds to charge the fuel line. Can you hear the fuel pump running? Without turning to start, turn ignition switch to on, listen closely for relay to drop out. If you hear it, then not issue.
Next is the oil pressure gauge. The fuel pump operation goes through the oil pressure gauge. If the engine does not get oil pressure, the fuel pump does not operate.
Remove air cleaner, check to see if the injectors are spraying fuel into the intake manifold.
Have you checked the fuel filter or replaced it?
