72cougarxr7
Aug 04, 2018Explorer
Yes, maybe my wording was confusing to picture.
What I meant was, it is fine to install the timing set with both marks facing each other, but before you button it up, if you rotate the engine 360 degrees so both marks are at 12:00, you will be at #1 TDC, and at the correct position to install the distributor.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
