turbojimmy
Aug 18, 2018Explorer
If you have adequate pressure at the rail and the injectors are pulsing but no fuel is coming out then the injectors are plugged. Don't trust the light - put a stethoscope on the injectors to hear them clicking. If they're clicking but no fuel is coming out then they'll need replaced.
Sort of related, I've had a #7 cylinder misfire in my truck's 5.3 liter engine for about a year. I don't drive it much so I didn't get to working on it until a couple of weeks ago. Swapping the coil, plug and wire from the #5 cylinder didn't fix it. At that time the plug looked good. No oil, not fouled. Compression check came up good. So I installed a new injector. STILL didn't fix it. Pulled the plug again and this time it was trashed from the lean condition in that cylinder - the insulator was cracked and it was burned up. So in the end it was originally a fuel delivery problem that turned into an electrical problem.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
