ernie1
Oct 15, 2013Explorer II
You don't mention what vintage nor model of rv you have but I thought I'd share with you what I experienced on my 1989 Ford E350 with a 460 engine. I had what appeared to be alternator issues in that the voltmeter showed only about 12v and not much more at any speed. Checked system and found that there is a fuse link in the system and it's located in the area of the battery. Checked it and it was good. Being on the road, I gave up and brought the rv into a Ford dealer which changed the alternator and things appeared better but not good. Upon checking further, turns out the in dash voltmeter was faulty! Who would have thought? I know you mentioned that you tried several meters.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
