EmeraldViking
Oct 31, 2013Explorer
I have a 1994 Hornet E350 RV. The chassis seems to be a 92 And changing the alternator has been no easy task. First the old ASI plug was apparently a 'D333'. It had only the y/w 'test' wire and the g/r 'indicator' wire next to each other. (No stator wire) So I had to use my own crimped connectors. I tried ignoring the second (output) plug. I wired the output to the battery directly with battery cable (including fuses), since the new one is a high output alternator. After I ran the motor there was an apparent cascade reaction that burned the 'indicator' wire after an old three wire connector even after the motor was stopped. I replaced that in similar fashion. The new alternator has not produced a charge since. I have re-partialy-drained the radiator to move the hose that blocks removal and removed the new alternator. I have made a new ASI harness. The individual wires may have just come loose. But after opening the sheathing on the second plug I noticed that the original b/o wires were spliced to much heavier yellow wires that seem to go indirectly to each battery. As well as a yellow/green wire that I have no idea where it goes yet. I wish they didn't bundle all the (maybe 100) wires together. Anyone familiar with this type of RV wiring?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
