ksg5000
Jul 10, 2016Explorer II
What top connection? On the outside you have the drain plug and up top you have a pressure valve. The inside of the tank has two connectors (inlet/outlet). All the plumbing parts are std/replaceable and found at most hardware stores. I wouldn't rush out an replace the hot water tank just because it's old - not if it's just a valve that needs replacing.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
