dougrainer
Jun 16, 2016Nomad
DrewE wrote:
Be careful with just removing it--the diode was presumably there for some reason, probably to prevent an unwanted power feed path. Check, for example, that you don't have the third brake light flashing with the four way flashers or something along those lines.
A DIODE is a 1 way electrical street. They are put there just as you stated---to prevent unwanted 12 volt feedback going to another circuit. The OP just needs to get a 20 amp rated Diode and install it where the original was. UNLESS, the DIODE was doing its job and by removing it the brake light power now goes where it should not go, while he has brake lights, there is power going somewhere else it should not go. Doug
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
