dougrainer
Jun 25, 2016Nomad
Chris Bryant wrote:
I really would not use Arctic Silver for this, as it would take a couple of thousand dollars worth to do the job, it's not formulated for this application. The supplied mastic does fine.
You should have explained the Mastic is called TRANSFER mastic. It is not an insulator, but facilitates the transfer of COLD to the Evap plate and the freezer walls. Also, you CANNOT use too much Transfer Mastic. Using too little will cause problems in cooling. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
