heebeha
Jun 30, 2016Explorer
Yes it is a rebuilt unit from RVcool.com and Yes it was upright for the past 2 days. Its upright now in the camper for the past 13 hours almost level.
They said to roll the fridge side to side after installing everything when I had the fridge on its back. I flipped the cooling unit side to side, upside down and around before Installed to when the fridge was on its back but did not roll it side to side after that.
Do you think I need to pull it back out and roll it side to side when its on its back?
I also tried to run it direct to 100v, the gas is not installed yet because I was waiting for paint to dry on the bracket. Do you think it all needs to be installed or plugging in direct to 110v (The 110 plug on the refrigerator to an extension cord to my homes 110) should suffice to make it work?
I only ran it for a couple hours like this, didn't feel any change in temperature inside and the top of the cooling unit, felt from the roof was hot, the tank at the bottom was not hot at all.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
